Ok, i am so lost here...
I have an AEM wideband twin channel, i followed the non-linear instructins, and its still not working right...I had a very accurate equation, but the AFR wouldnt pass 9A/F although i was actually at 15A/F
Here is a copy of my PID CALC
*UNITS
#Code System Abbr Description
A/F AEM 1 None AFR "Air Fuel Ratio"
B/F AEM 2 None AFR "Air Fuel Ratio"
# Add slot definitions here
# See sae_generic.txt for more information on "SLOT" formats
#Units Low High Fmt Expression
*CLC-00-001
A/F 8.41 19.44 .1 "(0.0129*{EXT.AD1}*{EXT.AD1})-(0.0362*{EXT.AD1})+9.5366"
*CLC-00-002
A/F 8.41 19.44 .1 "(0.0129*{EXT.AD2}*{EXT.AD2})-(0.0362*{EXT.AD2})+9.5366"
*PRN - Parameter Reference Numbers
# See sae_generic.txt for more information on the *PRN section
#Code PRN SLOT Units System Description
CALC.AEM_AFR1 F002 CLC-00-001 "AFR,V" O2-Wide "AEM Wideband"
CALC.AEM_AFR2 F002 CLC-00-002 "AFR,V" O2-Wide "AEM Wideband 2"
Please help...I need to get the widebands to work so i may finish off my tuning...
Thank you all for you time
Manaf
