Results 1 to 8 of 8
Thread: Can't unlock pcm
    Mar 2005
    Default Can't unlock pcm
    I recently purchased an 01 silverado 3500 dully 6.6 diesel. I was trying to read the pcm and efilive said the pcm is locked. I believe the previous owner had sometype of programmer on it. I want to know if I can do a full pcm rewrite to unlock the pcm and start over.
    Sometimes TIS actually stuffed these 01 ECM's up too!
    Next time you try to read it check out what the Seed value is (as shown on the screen as it tries to read).
    As far as I know nobody but EFILive can lock these ECM's, so if it were a handheld it might have 'damaged' the ECM more so than lock it. (Long story).
    Mar 2005
    The seed used is $cc74. What is also funny is when I use scan mode, the software has to reverify the pids and modules everytime I reuse the software. In the vin box at the bottom is shows just characters like ?!#@!. Is there anything I can do to tune this pcm?
    That isn't a good sign, when the VIN is scrambled it usually means the ECM has been corrupted at some stage. As I said, TechII will do that for you on a reflash. Quite common on a 2001.
    So, what can be done, well, next to pulling the flash chip off, programming it external to the ECM and putting something normal back in, not a great deal.
    If you were out here is Aus I could fix it for you, but, that aint so....try contacting wait4me on this forum.
    Mar 2005
    I have a friend with an updated tech II. Can he reflash or fix the pcm for me.
    Aug 2004
    No a tech2 wont fix that. It was the cause..
    Send it to me if you would like, with your vin number on a piece of paper, And ill pull the chip and fix it for you.
    Quote Originally Posted by wait4me
    I have the same problom on my 01
    i ordered a road runner will i be able to just use it?
    2017 Trailblazer 2.5L Dmax
    07 LBZ rc lb EFI - Sold
    05 lly cc lb, EFI 80hp tune-Sold
    01 lb7 rc lb EFI & Road Runner,1000+hp -Sold
    Duramax power
    Aug 2004
    Roadrunner will work fine.
  1. How can I unlock a PCM
    By imtduncan in forum Gen III V8 Specific
    Last Post: February 19th, 2009, 08:12 PM
  2. ECM Lock and unlock
    By markgammel in forum General (Petrol, Gas, Ethanol)
    Last Post: October 7th, 2007, 02:59 AM
  3. How do I unlock the PCM?
    By -=Mod=- in forum General (Petrol, Gas, Ethanol)
    Last Post: April 28th, 2007, 12:06 PM
  4. Unlock the PCM
    By ASSAMI in forum RoadRunner Real-Time PCM Emulator
    Last Post: February 15th, 2007, 05:49 AM
  5. TCC Unlock Problems
    By Rontune in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 7th, 2006, 09:46 AM
