Some info i put together from the web
nice post gelf!
I think there are different assumptions for PE or WOT. 14.7 there would be a threat to all that you hold dear.
PowrMax Performance
100 mm PowrMAF
Yes it is...and that's where the Auto VE tutorial is wrong/misleading also.Originally Posted by mr.prick
Howard
DUCT TAPE.
98 K1500 'HOLDEN' Suburban.
Nice info, tnx!
Garry Glendown * '17 Fifty 2SS MT * 99 Firehawk Convertible (for sale)
Suppose it depends on how many decimal places you are showingOriginally Posted by mr.prick
Stoich for gasline is published as being 14.68 which is ~14.7.
How is the VE tutorial misleading? Its states 14.63, is this because you don't want to command stoich during AutoVE and you should command 14.7 like I have read in COS threads?Originally Posted by hquick
Yep!
Howard
DUCT TAPE.
