Results 11 to 20 of 26
Thread: BB Logging update Nov 28, 2007
  1. #11
    Senior Member Hyper99's Avatar
    Oct 2005
    Success! Logged both to internal memory and SD card.
    In the Config.INI file I see where the PIDS are defined as to which ones to log.
    PCM, ECT, 0:110:1:1:0
    PCM, MAP
    PCM, RPM, 0:6500:2:1:0
    PCM, VSS
    PCM, SPARKADV
    PCM, IAT
    PCM, TP
    PCM, SHRTFT1
    PCM, LONGFT1
    PCM, SHRTFT2
    PCM, LONGFT2
    PCM, KR, 0:0:3:1:5
    PCM, HO2S11
    PCM, HO2S21
    PCM, IBPW1
    PCM, IBPW2
    PCM, TOS
    PCM, GEAR
    What other PIDS are usable?
    99 Silverado 2500 Extracab Longbed
    33" BFG's - American Racing Rims
    Custom Dual Upper console gauge mount w/Autometer Sport Comp - Pyro, Oil Temp
    Autometer Sport Comp Boost/Vac in Custom Hypersonic Gauge Mount in dash
    LS-1 6.0L w/AFR 205cc Street Heads
    Vortech V2 blower
    42# Injectors
    Comp Cam - Custom Street Grind
    TTS Catback Exhaust
    Innovate LC-1 Wideband O2
    Tune and Trans mods via EFILive V1-V2
  2. #12
    Quote Originally Posted by Cougar281
    Maybe I'm doing something wrong, but I'm still not getting any data in standalone. The timer increments, but no frames are logged and no data is displayed next to the PIDs. After teh update, I formatted the config flash and copied all the PMM files and the options.ini back.
    Also, still getting the $0311 when I try to clear DTCs on my LLY.
    Can you clear codes and log data using a laptop in passthrough mode?
    If so, can you please connect up FlashScan to your laptop and LLY and click on the connect button, then clear codes, then log about 10 seconds of data. Stop logging and select File->Generate error report. Save the report and email it to me at paul@efilive.com.
  3. #13
    Quote Originally Posted by Hyper99
    PCM, MAP
    PCM, VSS
    PCM, SPARKADV
    PCM, IAT
    PCM, TP
    PCM, SHRTFT1
    PCM, LONGFT1
    PCM, SHRTFT2
    PCM, LONGFT2
    PCM, KR, 0:0:3:1:5
    PCM, HO2S11
    PCM, HO2S21
    PCM, IBPW1
    PCM, IBPW2
    PCM, TOS
    PCM, GEAR
    The available PIDs are listed in the *.txt files in the Pid Descriptions folder. Read the Readme.txt file in that folder for more info.
    The PIDs currently available are only about 20% of what is available in total. We will add in the rest once everything is working properly.
  4. #14
    Just re-checked the LLY and found similar problems. I think its just a configuration problem. Working on a fix now...
  5. #15
    Feb 2006
    I was typing a message about my problems updating the firmware...however all now sorted.
    Whilst typing my message I ran EFILive Explorer so that I could transcribe what I was doing accuratly.....HA! it wouldn't let me type in this window while it was running (XP running dual screens), I could click the browser window and transfer focus, scroll up and down OK, just couldn't type.
    Not an issue for me in anyway, just thought you might like to know.
    Jim
  6. #16
    Quote Originally Posted by Happy Jim
    Jim
    Got a USB keyboard? Sometimes my keyboard stops working (on Vista), I just unplug - replug it and it is all good again. Not sure what is causing it. It only fails when I have another USB device plugged in to the socket next to it - i.e. on the same hub.
  7. #17
    Senior Member Wasted Income's Avatar
    Dec 2005
    I updated to the newest firmware, but do I have to re-update the bootblock with today's update?
    2005 Silverado Duramax LLY - EFI Live Tuned
    1969 Chevrolet C-10 Pickup - Turbocharged 5.3L/4L80E - EFI Live Tuned
    1975 Avenger Jet Boat - 6.0L/Berkley pump - EFI Live tune in progress
  8. #18
    Quote Originally Posted by Wasted Income
    No, the bootblock update is only required to be done once.
    Actually you can't do the boot blockupgrade again because the option to upgrade the bootblock is only in the old 2.4 firmware. Now that you have updated to the 2.5 firmware you can just run the EFILive_Explorer program and use the firmware programming option in there. You also don't need to do the "hold down the Ctrl key" thing anymore either when programming the firmware.
  9. #19
    Dec 2005
    Thanks Paul! Just went out and tested it out. Works great on my LSx, does not work on my LLY.
  10. #20
    Feb 2006
    Keyboard is fine, while I've got the "Reply to Thread" window open (ie I'm in the middle of replying to a post) if EFI Explorer is running I can't type in the "Reply to Thread" window - I can click into it and get the flashing curser...just can't type anything. As soon as I close EFI Explorer all is fine again (I'm on IE6 if the browser has anything to do with it).
    No biggie though
    Cheers
    Jim
  1. BB Logging Update Dec 31, 2007
    By Blacky in forum FlashScan V2 BB Logging
    Last Post: January 9th, 2008, 02:59 AM
  2. BB Logging Update Dec 20, 2007
    Last Post: December 29th, 2007, 09:11 PM
  3. BB Logging update Dec 01, 2007
    Last Post: December 19th, 2007, 12:41 PM
  4. BB Logging Update Dec 14, 2007
    Last Post: December 17th, 2007, 03:26 PM
  5. BB Logging Update Dec 6, 2007
    Last Post: December 13th, 2007, 02:34 PM
