Hello
I'm after a copy of pinouts for the E38 PCM. If anybody has a copy could you please post it up .
I have searched high and low on the net without success.
Cheers
Les
Hello
Cheers
Les
Have done the same thing few months back & no luck
I think you just needed to be looking in the correct location. Try here:
http://www.ls2.com/forums/showthread...40#post6553040
Elmer
2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
Sure thing. The E38 pinouts are listed as 2007 Vette E38 01-06. The Other pinouts are for the 2005 GTO (LS2)
I am looking for E40 PCM pin outs for the Trailblazer 5.3 or 6.0 I especially need the pin outs for requested torque and delivered torque to the ABS module. I need this info to see how to wire a 2004 Colorado harness to it thanks!
A very good source:
www.repairprocedures.com
Most/all models covered.
Thanks! That is an awesome website! Do you know if you can change the pinonts in the programming? I think the Colorado uses the same plug but the order of the pinouts are different? Thanks
