Looking closer at my log in post #26, the timestamps are all incorrect.
That's what I see when viewing the log file using the scantool...Originally Posted by Goldfinger911
but when I was recording the log, V2 showed correct values (they showed that my car was at warm idle).
I had a similar issue with seemingly corrupt files. I noticed that my corrupt files corresponded to the blue LED not flashig while logging data.
I reformatted my SD card and the issue seems to have went away. For the root cause, I have no idea.
Ok, I'm reformatting as I read write this...
Edit: reformatting via the V2 commands, right...?
Right. Did it work Joe?
Al
You can't play back a log on FlashScan.Originally Posted by joecar
In future it will be available.
The "Display" option just displays real-time PID values without creating or writing to a a log file.
The corrupt log files is due to a mismatch in the PID definitions of the wide band O2 status PIDs: WO2ST1 and WO2ST2. They are defined as 16 bit values in the PC scan tool and only 8 bit vales in the FlashScan *.pmm files. That causes the PC Scan Tool to read frames 2 bytes too long from the log files which means after the first frame, the data turns to junk (or FlashScan is writing frames 2 bytes too short - depends on your point of view).
I haven't tried yet, but I'm pretty sure if you remove both of those PIDs form the Options.ini file PID list(s), the problem will go away.
I will fix it in the next update.
Hi Paul,
maybe I have the same problem.
I did a clean install (on a new PC) of V 7.5 and unzipped the latest BB update over the existing files. The previously logged BB files seem corrupted while viewing with EFI live scantool (V7.5.4 build 46), but on the old (not updated) Laptop installation everything is displayed ok.
Marco
If i try to use this latest update March 26th to look at BB logs captured with the Mar 20th edition they are all garbled on the screen for some reason??
Oztrack
EFILive Tuning Consultant
Worldwide Remote Tuning Service
2006 NSW Super Street Drag Racing Champion
www.oztrack.com.au
I deleted WO2ST1 and WO2ST2 from Options.ini, I re-logged, and now the scantool correctly displays the log (see attached)...
Altho the scantool shows [Manual].
Also, in Options.ini I replaced AFR with EQIVRATIO, and during logging V2 shows EQIVRATIO units as "V";
it's units should be "EQ" or nothing.... can I change this...?
