Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 117
Thread: PLX SM-AFR Serial upgrade
    Mar 2004
    Default PLX SM-AFR Serial upgrade
    Hi jez came up to mackay for the weekend and we worked out what parts & pids are needed for a PLX SM-AFR to output serial data in to your V2 cable & in passthrough mode
    3 wire is all the is needed in side the SM-AFR and a serial cable with a RJ12 crimped on
    the parts are off ebay it took just over a week to get to OZ
    http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=160220472353
    Geoff
    Sep 2003
    Just modded my PLX also for serial coms. Works great.
    Lifetime Member JezzaB's Avatar
    Nov 2006
    Certainly made my life sooo much easier after I did it. Couldnt go back to analog now.
    Jez
    Lifetime Member MICK's Avatar
    Mar 2005
    Default Hummm
    Thanks Guys the pictures answered all my questions.
    Nice work!
    Mick
    Rev it up, Drop the clutch, See what happens?
    Lifetime Member Mr. P.'s Avatar
    May 2007
    Hi, I'm only half-following here - what's the purpose of doing this? Are you monitoring the WB with a PC via serial???
    Mr. P.
    Nov 2006
    Quote Originally Posted by Mr. P. View Post
    Mr. P.
    The V2 unit has a RS232 serial interface. Instead of logging with analog where alot of us are getting voltage offsets and its throwing the AFRs out. You connect the PLX to the V2 so you get a pure signal from the PLX as the PLX see's it, straight to the V2.
    Nice accurate AFR readings
    Jez
    PS The TTL converter board is a 3-5v board, so if you tap the regulated power to the PIC chip inside the PLX, it supplies a nice and stable 3.54v (red wire) to power it.
    Allows V2 to read the AFR from the wideband in digital form (i.e. what the wideband's controller says it is).
    Nice work you guys...
    Lifetime Member Chalky's Avatar
    Sep 2003
    For the technically challenged, after adding the three wires, where would I find the cable for the serial adapter to the V2?
    2015 Z06 A8
    Mar 2005
    Default Hummm
    I purchased everything I needed to make a plx cable from jay-car.
    6 x RJ12 plugs for $1.80 (This was the smallest quantity).
    1 meter flat stranded 6 core wire cable $0.90.
    1 x D9 shell $1.80.
    1 x D9 plug $1.20.
    I lashed out...LOL
    Quote Originally Posted by Chalky View Post
    The serial cable ships with FlashScan. It has an RJ12 plug on one end to fit into FlashScan and a 9 pin serial plug on the other end.
  1. BBL & Serial LC-1
    By L31Sleeper in forum FlashScan V2 BB Logging
    Last Post: January 19th, 2010, 12:01 PM
  2. plx sm-afr serial
    By blazinblue in forum General
    Last Post: June 23rd, 2009, 08:29 AM
  3. Replies: 50
    Last Post: March 15th, 2009, 04:00 PM
  4. Where are we with serial WB???
    By Redline Motorsports in forum FlashScan V2
    Last Post: August 13th, 2008, 09:26 AM
  5. WB serial to LT serial?
    By Bruce Melton in forum General (Petrol, Gas, Ethanol)
    Last Post: May 12th, 2008, 10:17 AM
