Page 1 of 11 123 ... LastLast
Results 1 to 10 of 104
Thread: BB Logging beta update: April 14, 2008
    Default BB Logging beta update: April 14, 2008
    IMPORTANT
    IF YOU HAVE NOT ALREADY DONE SO,
    YOU MUST UPDATE FLASHSCAN'S BOOT BLOCK TO V2.05.07(0414)
    BEFORE
    YOU ATTEMPT TO UPGRADE THE FIRMWARE TO V2.05.16 OR LATER.
    Under no circumstances should you attempt to use boot block V2.05.06 (released March 26, 2008).
    See this link for more info on what is wrong with V2.05.06
    http://forum.efilive.com/showthread.php?t=7804
    Download here:
    http://download2.efilive.com/Softwar...il_14_2008.zip (19Mb)
    This download includes and supersedes all previous BBL beta downloads.
    Please read the Readme_First.pdf file included in the zip file.
    It contains important, updated information about how to upgrade the boot block in your FlashScan and/or AutoCal devices.
    Make sure you update your FlashScan (and/or AutoCal) firmware and boot block using the latest firmware file(s) in the EFILive_Hapi folder.
    Please read the first posts in the March 20, March 26 and April 07 releases so that you are aware of the previous versions' pre-requisites.
    http://forum.efilive.com/showthread.php?t=7643
    http://forum.efilive.com/showthread.php?t=7566
    http://forum.efilive.com/showthread.php?t=7747
    Lifetime Member Kevin Doe's Avatar
    Aug 2007
    As compared to the April 7th release, what is upgraded here? Just the bootblock?
    Nothing to see here :lol: - my mistake
    Quote Originally Posted by Kevin Doe View Post
    The boot block, the firmware and the V7 software, the DVT controls and some *.calz files.
    Almost everything got updated.
    See the Release notes pdf file for exact details on what got updated.
    Paul, just an FYI I upgraded to the 4/7 bootblock last week and didnt have a problem. Although I upgraded it and then it sat until 5 min ago when I reprogramed the 4/14 boot and firmware no problems. Also figured out how to look select BBL files, too bad I cant test the P10 for ya. :(
    You can try testing any controller with BB Logging. Just select/use a controller with the same protocol (i.e. VPW or CAN) and then only choose* from generic PIDs.
    * i.e. only include generic PIDs in the *xxx_PSL section in Options.ini.
    I know, the P10 file is linked to the LS1 PSL section. My problem is I dont have a car to test it with!! So that kinda makes it hard, Ill test it here in 3 weeks.
    Ohh I see.
    Its ok, Ive been dying without my ride... Counting down the days, May 11! Then Ill probably revamp my tune again haha.
    FUELSYS pid now displays correctly in scantool.
  1. BB Logging beta update: April 26, 2008
    By Blacky in forum FlashScan V2 BB Logging
    Last Post: July 19th, 2008, 03:44 PM
  2. BB Logging beta update: May 19, 2008
    Last Post: June 11th, 2008, 09:22 AM
  3. BB Logging beta update: May 12, 2008
    Last Post: May 27th, 2008, 08:01 AM
  4. BB Logging beta update: May 06, 2008
    Last Post: May 22nd, 2008, 09:57 AM
  5. BB Logging beta update: April 07, 2008
    Last Post: April 14th, 2008, 09:31 AM
