Page 3 of 13 FirstFirst 12345 ... LastLast
Results 21 to 30 of 122
Thread: BB Logging beta update: April 26, 2008
  1. #21
    Quote Originally Posted by Hyper99 View Post
    Had the same problem with the Exeption Error
    Noticed that when programming the firmware, EFI Explorer used to give a percent of completion. Mine just sat there, and finally said complete......Strange.....Hope it works tomorrow.
    From the Readme_First.pdf file:
    While FlashScan's firmware is being programmed a "percentage complete" counter will be displayed from 0% to 100%. Sometimes that counter may "freeze", however the reprogramming process will continue. It should be complete in less than 20 seconds. A dialog box indicating success will be displayed when the programming is complete.
    I do not know why that happens. It happens outside of EFILive_Explorer's control. :( If I ever figure it out I'll fix it.
    Regardless, if FlashScan boots normally (not into dead poll) then you can be sure that a firmware update was successful. FlashScan has built in CRC checks similar to the GM ECMs which will gaurantee that the data programmed into FlashScan is 100% correct.
    If even just 1 bit of 1 byte is wrong, FlashScan will boot into dead poll forcing you to retry the firmware update.
  2. #22
    Jan 2005
    Upgraded to 2.5.08 boot block and 2.05.17 (427) with no problems. Logging worked fine. One thing I did notice is that in the Options.ini file under PSL_LS2, the node for FuelSys is listed as PCM. Every other node is ECM or TCM. This probably has no effect on operation, but it "looks" like a mistake and may be the cause of some confusion in the future.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
  3. #23
    Jan 2008
    ok so i just did the update, everything went good i was able to record a log with the v2. now how do i read it in the scan tool?
    2005 lly crew cab long bed
    k&n filter
    mbrp 4" turbo back (not cat)
    egr blocked
    carter lift pump
    suncoast IV w/1056
    straight centerlink and tierod sleeves
    efi live by mcrat and team salad
    ppe race valve and ported fitting
    tobyk321@yahoo.com
    13.06@102.7 4/13/08
  4. #24
    Oct 2006
    Can we use the Digital data from the wide-band in pass through to log BENs for AutoVE and other processes ?
    If so how , did I miss a key process somewhere ?
    2006 Trailblazer
  5. #25
    Is this a stable release?
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
  6. #26
    Oct 2006
    Quote Originally Posted by tunedbyGM View Post
    Never mind found this in a old thread :http://forum.efilive.com/showthread....l+data&page=15
    Post #143
    2006 Trailblazer
  7. #27
    Post #143
    The PID you should log is one of these: (taken from sae_generic.txt)
    Code:
    CALC.BEN1     "BEN Factor Bank 1, Serial Wideband, LS1 style"
    CALC.BEN2     "BEN Factor Bank 2, Serial Wideband, LS1 style"
    CALC.BEN1_B   "BEN Factor Bank 1, Serial Wideband, LS2 style"
    CALC.BEN2_B   "BEN Factor Bank 2, Serial Wideband, LS2 style"
    CALC.BEN1_E38 "BEN Factor Bank 1, Serial Wideband, E38 style"
    CALC.BEN2_E38 "BEN Factor Bank 2, Serial Wideband, E38 style"
    "Bank 1" and "bank 2" correspond to wide band controller 1 and wide band controller 2 respectively if you have two controllers.
    Otherwise if you only have one wide band controller always use "Bank 1" - even if your O2 sensor is in bank 2.
  8. #28
    Feb 2005
    I keep getting this when trying to install V2.04.72.ffw
    the two leds are flashing (dead poll)
ID:	3158   Click image for larger version.
Name:	firmwre screen.jpg
  9. #29
    Have you started with BBL beta firmware yet or are you trying to get to a point where you can begin beta testing? If you already have an older version of the BBL beta firmware then you need to use EFILive Explorer in the V8 folder to program FlashScan V2.
  10. #30
    Feb 2005
    do you mean this? i have intsalled the first release of bbl beta software.
    i have programmed V2.05.08 (bootblock) when i hit the refresh button V2.05.04 (bootblock) comes up
  1. BB Logging beta update: May 19, 2008
    By Blacky in forum FlashScan V2 BB Logging
    Last Post: June 11th, 2008, 10:22 AM
  2. BB Logging beta update: May 12, 2008
    Last Post: May 27th, 2008, 09:01 AM
  3. BB Logging beta update: May 06, 2008
    Last Post: May 22nd, 2008, 10:57 AM
  4. BB Logging beta update: April 14, 2008
    Last Post: April 23rd, 2008, 08:46 PM
  5. BB Logging beta update: April 07, 2008
    Last Post: April 14th, 2008, 10:31 AM
