Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Just went from OLSD to CLSD, some questions
    Lifetime Member Kevin Doe's Avatar
    Aug 2007
    Default Just went from OLSD to CLSD, some questions
    EDIT: Sorry for the wide pics, I have a widescreen monitor.
    For the first time I switched from open loop speed density to closed loop speed density. I figured I might pick up a mpg or two by doing so.
    I during my last fine tune of my VE talbe I did some minor tweaking. I did probably an 1.5 hour drive hitting a lot of the cells. The corrections were small.
    Here you can see my BENs from my logging process. In this screen shot I'm hiding cells with lower than a cell count of 50, and filtering the data. Most cells have 100 counts or more. Many of the cruising cells have 1000 data points.
    Then I took that BEN data, applied it, and did some smoothing. I also used some WOT pulls and hard engine deceleration logs to get the cells you cannot sit at steady state.
    This is a screen shot of the % change from the tune while logging, to the new tune I just loaded. As you can see, in the main part of the map where you'd be cruising the % changes are very small, and very close to the BENs from the logging. Positive numbers mean that I corrected it in the leaner direction, just as the BENs told me to do.
    So I took that new map, put it into a new tune. Then I turned on the closed loop fueling, and turned DFCO back on. Went out and drove maybe 5 seperate times, for a total of 2 or so hours of driving. Then I took a screen shot of my long term fuel trims for bank 1 and bank 2. I am very very confused by how far positive they are.
    Here are the LTFTs
    Bank 1
    Bank 2
    When I look at some logs to see what the wb02 says its doing in closed loop I see that the BENs come out to about 0.98. I'm really confused on what is going on here. When cruising I see that the FUELSYS says that I'm in CL-Fault mode, and switches to OL when I get on the gas heavy. Is CL-Fault mode correct for a speed density setup? I'm thinking it is, but not sure.
    My setup consists of basically a big cam only motor. I have long tubes, 3" exhaust w/o cats, and a dual 3.5" intake. Pretty basic setup. I have a texas speed MS4 cam.
    I'm not sure what is going on these trims, and why they say my maps are sooooo lean. Any help or input here would be greatly appreciated. Also, my WOT is spot on now, and I don't want any stupid trims to be added to them making it overly rich.
    I have attached many files. Here is a description of the files I've attached.
    5-3-2008_002.tun is the baseline tune I was using when I did the VE BEN logging.
    5-4-2008.tun is the new tune that I created from the logged BENs. I also switched to CLSD, and turned DFCO back on.
    5-4-08 VE BEN main.efi is the long log from my VE BEN logging.
    5-7-08 Work Commute 2.efi is a ~20 minute drive to work. Following this last drive is when I took the screen shots of the LTFTs.
    Jun 2005
    Assuming you have headers that move the O2's back down the exhaust path...
    Do you have a seperate bung for your WBO2 so you can run it along with the NBO2s? If so, you may have to reduce the O2 switchpoints until closed loop maintains a stoich AFR. Try dropping them 8% for starters and see where it puts ya.
    Aug 2007
    I have 1 7/8" long tube headers. The NB02 bungs are pretty far back. Probalby about 1/3 back on the transmission, or more.
    Here is a pic of my headers before I installed them.
    8% on the switchpoint? I'm not on a computer where I have EFI Live Tune tool. If I remember correctly the stock switch point is 450. So you propose trying 414 for those values. Its a curve if I recall correctly. Change all of the values to 414 and try that. Any explanaion of why the switch point needs to be different based on being further downstream.
    I do have seperate bungs for the NB02s and WB02. I have the WB02 after the X pipe to try and get an average AFR.
    Jun 2005
    Yeah, try setting them to 415 or so. It should lean out the point the fuel trims hang around. Think of the STFTs as a sin wav. The STFT's go + and - during closed loop. The average of the STFT's can be found by drawing a line down the middle of that sin wave (green lines below). If the line you just drew is above what the PCM thinks is stoich (i.e. the switch point - red lines), it assumes you're running rich and the LTFTs go in the negative direction. If the average line is below that switch point, it assumes you're running lean and the LTFTs add fuel.
    In your case, the LTFTs are adding fuel. So, you need to lower the switch point line. Make sense?
ID:	3243   Click image for larger version.
ID:	3244   Click image for larger version.
    Aug 2007
    A few more questions.
    1. Why try 8% less (415)? Why did you pick that number.
    2. I see that you can adjust the LFTF boundaries on for both the MAP and RPM boundaries. Since I have a large cam, does it make sense to update the boundaries to more reasonable values that I see with my big cam. If this is commonly done, can you suggest some boundaries to try. In the meantime I'll research and see what I can find on this subject.
    Thanks!
    Jun 2005
    I suggested 8~10% because of someone else's recent post in another thread (that I can't seem to find right now). Also, because it's not that big of a change and you'll be monitoring the results with your WBO2. My intentions and suggestions are rarely 100% accurate....but rather more in line to get you going in the right direction.
    As for adjusting the boundaries, if the tune is spot on for all of the MAP/RPM's you drive in, why would you need to move these? If you do, I'd bump them up a little - but not a whole lot. Just my $0.02...
    Aug 2007
    In open loop I was spot on, so I don't see why closing the loop would change things otherwise. I'll report back with my findings!
    Oct 2006
    The problem stems from the narrowband being sensitive to exhaust gas temperature. Moving the sensor further away from the cylinder head places the sensor in much cooler exhaust gases, changing the voltage output. In the attached chart I got from the innovate site you will see that sensor output can be between 150mv to 650mv at stoich. This will give ample room to set the switchpoints to suit your new sensor position.
    By using the highlight function in the scan tool you should be able to average the O2 sensor voltage to give an idea of the switchpoint. The same highlighted area will give you an average AFR off your wideband, telling you if you need to adjust the switchpoint up or down. Logging GM.DYNCYLAIR.DMA will tell you which CL mode you are using so that you adjust the correct switchpoint.
    Hope this helps,
    Mick
    The Tremor at AIR
    Jan 2005
    Wouldn't it stand to reason that if you disabled CL fueling the NB's voltage should draw a straight(er) line for a given AFR? (Kinda like when NB's peg at 800+ mv at WOT)
    If so, you could monitor AFR with the WB and associate stoich to the respective NB voltage. At that point you would know which way to move your NB switch points.
    Jun 2005
    Quote Originally Posted by TAQuickness View Post
    Assuming you monitor based on which CL Mode you're in, I don't see why not.
  1. Question about my tune 98 OLSD
    By rickou812 in forum Gen III V8 Specific
    Last Post: November 21st, 2009, 11:26 AM
  2. cos3 sem-clsd
    By aaronr in forum Custom Operating Systems
    Last Post: March 16th, 2009, 03:53 AM
  3. Switch from OLSD to OLMAF
    By Alex99 in forum Custom Operating Systems
    Last Post: February 9th, 2009, 03:54 AM
  4. CLSD tune runs great 30 min later rich at idle
    By louis in forum General (Petrol, Gas, Ethanol)
    Last Post: October 7th, 2007, 12:57 AM
  5. autove OLSD good CLSD iffy
    By stigmundfreud in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2007, 12:54 PM
