Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: wrong firmware and boot block
    May 2008
    Default wrong firmware and boot block
    I screwed up already... Somehow I have my Firmware ver. is 2.05.17, while my Boot Block ver. is 2.05.04.... I don't know how I managed that (well I do, but don't know what I was thinking). Even after reading the readme..
    So now I can only seem to connect to V2 with EFIlive_explorer while the V2 is in dead poll... so obviously am unable to update the boot block to the 2.05.08 which I'm not so sure would even be possible that way anyhow.... I think I done did it this time....
    Can anyone lead me in the right direction as to what I should do now...
    Thanks a bunch
    TW
    Quote Originally Posted by t_dubble View Post
    Thanks a bunch
    TW
    Flash in the firmware version FSProgV2_05_15(0326).efw (that matches the V2.05.04 boot block).
    Then upgrade the boot block to FSBootV2_05_08(0426).efw
    Then flash in the firmware FSProgV2_05_17(0512).efw
    All those files should be in the May 12, beta download.
    May 2008
    Worked Perfectly.... Thanks for the quick response...
    Now that I have that part of it straightend out I'm gonna slow down a bit...
    thanks again,
    cheers
    TW
    Jun 2007
    I think I need to do this but I can't find the FSProgV2_05_15(0326) file on my computer. Where can I get it to get my V2 straightened out?
    That firmware should be in the folder:
    \Program Files\EFILive\V8\Firmware.
    If it is not, maybe you don't have the latest update from here:
    http://forum.efilive.com/showthread.php?t=8103
    I have attached it to this post in case anyone else needs it.
    Jun 2007
    Thank You Very Much.
    Jun 2007
    I'm good now with Firmware V2.05.17 and boot block V2.05.07.
    Looks like I'm working again.
    Thank you Paul.
    Quote Originally Posted by SOMhaveit View Post
    Thank you Paul.
    You should be on boot block V2.05.08
    Jun 2007
    OK. I guess I need to find that.
    Jun 2007
    Done. Thanks.
  1. Need help updating boot block (cracked screen)
    By slopokegtp in forum FlashScan V2
    Last Post: April 19th, 2010, 12:11 PM
  2. Error $0023 when trying to update boot block
    By Sparky8370 in forum FlashScan V2
    Last Post: October 26th, 2009, 03:00 AM
  3. boot block mismatch error
    By jrh in forum E37, E38 & E67 PFI ECM's
    Last Post: October 26th, 2008, 05:51 AM
  4. Boot block upgrade failures - Explanation
    By Blacky in forum FlashScan V2 BB Logging
    Last Post: April 15th, 2008, 09:38 AM
