I was looking for an injector, throughout the search I did, I collected the attached info. Really I like to share it with u and I'll be glad if it gets sticky in General Tuning Information under fuel injection section.
Regards,
Odd Boy
When I looked up the numbers for the 8.1 marine injectors on your chart I found them different than what I was led to believe...#17113739. I was led to believe they flowed 43lb/hr at 58 psi rail pressure 5.418g/s or 0.717 lb/min., and that they were rated at 37lb/hr at the standard 43.5 psi fuel rail pressure. Does anyone know for sure?
refer to the following for your injectors:
http://www.racetronix.com/17113739.html
or
http://www.thunderracing.com/catalog...id=163&sid=380
Regards,
Odd Boy
I just saw this...![]()
FLASHSCAN V2 & AUTOCAL
