I am new to EFILive and am currently having issues getting my fuel gauge to work, gauge is currently pinned at full. The repining was already performed when I purchased the car and I attempted to tune the vehicle but the PCM was locked (fuel gauge working with original PCM). I installed a new pcm out of a 2000 Tahoe and everything is perfect with exception of the fuel gauge.
I have searched on this subject and found that I will need to do a fuel system segment swap (Edit>copy entire segment) using an 02 express van found on holdencrazy.com. Then copy over the tables from the original 98. The only issue is the fact that I cannot click on the copy entire segment from the express van file. What exactly needs to be done? Do I have to license the express van file? Please help I need a gas gauge. Thanks in advance!
