2 Attachment(s)
Curious about Allison 6 speed solenoid logging
I was playing around with stand-alone logging to answer someone elses post in another forum site. But I setup a BBL and selected only the TCM AL6 for my Allison 6 speed. I had selected the shift solenoids but they do not show correct for the gear selected. I figure since there was 5 of them they refer to the 5 clutch packs. only the first 3 show any activity and some gears show the same ones.
I selected the PCS1CP, PCS2CP, PCS3CP, PCS4CP, PCS5CP. But only first 3 show anything on them. I will add a log showing those pids and the gear the Allison is in at the time.
So from what I know the following clutch pack combo produces the following gear. Is the following correct?
1st C1 C5
2nd C1 C4
3rd C1 C3
4th C1 C2
5th C2 C3
6th C2 C4
reverse C3 C5
I currently running
V7.5.6 build 99
V8.1.2 build 75
firmware and bootblock fully updated from those versions.
Thanks for the info and to whether the AL6.pmm is correct.
Brian
