1998 Vortec timing and fuel issues
I am having a beast of a time with a 1998 Vortec that has been BUILT, stroked to 383, and has a Whipple strapped to it.
We dropped the compression to 8.9:1 and at this air density it is running 5.5 psi_g of boost.
This some o' the bitch is giving me fits. No matter what timing I put to it at idle it will not go above 16-18* of timing. My cell tracing is working (THANK YOU BLACKY!) and I am putting in the values all around the traced cell to try and force it. No-Go. I know she wants around 22 or 28 to idle smooth and this is burning me up. Once the throttle is open and up in the RPMs the desired timing is present both on the log and manually looking at it with a timing light.
Also I am seeing something I have never seen before and hoped someone has experienced this and can point me in the right direction. My LTFT are showing Bank1 at -5.3-ish, but Bank2 is showing -14.3-ish. My 02 sensors are showing a great response and sweep...but this is troubling me. As far as the customer knows the 02s were done about 15k miles ago so they should be fine. The exhaust is solid and no leaks.
Any help will be greatly appreciated,
-Kenny
Do you have a wide band o2?
4 bar should be 58 -62 psi w/ 40lb hr injectors. do you have a wide band sensor and and adjustable fuel regulator? On my 98 vette my AFR is right on and so is the psi but my LTFT average is what I use and they are -.8 bank one and 0 on bank 2. my short term is 3.2 bank one and 1.6 bank 2 and average 3.2 and 1,6 to -1.6 to -3.6. GMPP says this is OK. The 98 pcm is hard as the PROM is different than 99-02 pcms. Just so my afr is good and HP and trq and fuel rail psi are as advertised I wouldnt be to upset. It could even be VE and spark. B00sted and high performance are apps are kind of different on a 98. Check and see if P1336 is off on most 98 I have found this is disabled and enable P1336 and see if it needs a crank relearn. If so follow the relearn and try again. Food for thought :cheers:
98 tigershark
