1 Attachment(s)
E40 VATS Patch not working
Customer swapped a 2006 LS2 with E40 got a PCM tuned by another place and they locked it. The rig was not running correctly so I said lets put another PCM in that is not locked. I had another E40 and tuned it for him. I disabled VATS via the patch and full flashed it. Well, its not working. I have attached a log, take a look at VTD-VTD1 and 2. This is with ignition on engine off, it does the same if you can get the engine running. It just runs very very very fat. The only thing I can see making it run like that is VATS. Or am I crazy??
I am using V8.2.2.238 and v7.5.7 build 246
Attachment 16903
