Bank1 and Bank2 way off on fueling...
I have up to a 12% swing from the left to the right with STFT, the O2's are all out of sync and the wide band O2 is also all over the place.
I have spent several hours looking over the headers for leaks and there just are no signs of leaking at all period. I'm confident there's no exhaust leak so lets take that out of the equation.
I then took my infra read heat gun and measured the headers about 2" from the flange. All the tubes on Bank2 are far hotter, in fact several hundred degrees hotter then Bank1. This now backs up the O2 readings that Bank2 is lean.
The car runs good, has a lot of power but it has a shake at idle and just off idle plus it sounds like the cam is far larger then whats in there and I'm wondering if the huge imbalance between banks would account for this? Plus I would like it to be correct and as even as possible
What would make an entire Bank lean?
Lee
BTW, this is my firebird with a vortec 454 and 0411 with custom OS
