[B]HELP[\B] Another Dead PCM
HELP
Well it has happened again with another PCM.
A mate removed the blower off his car and I attempted to flash in a modified mafless tune. However once again the PCM will not flash and I can no longer read the PCM. I am using the same OP system that came out of the PCM just modified.
Since the last problem to the current one I have successfully flashed other vehicles including my own.
This happened a couple of weeks ago with a E38 PCM. (Thread already created).
This time I am attempting to flash a VZ LS1 1024kb PCM and got the following message.
15:41:39.125: Scanning for EFILive FlashScan V2 USB
15:41:41.656: Scanning for EFILive FlashScan V2 HAPI
15:41:41.843: Interface firmware version: 2.6.6
15:41:41.890: Interface firmware model: FSV2
15:41:41.906: Interface firmware version: 2.6.6
15:41:41.921: Interface firmware date: Dec 14, 2008
15:41:41.937: FlashScan serial number: 003689852244
15:41:41.953: FlashScan license number: 003689852244
15:41:41.984: Disconnecting ...
15:41:42.437: CAN-VPW Bridge Deactivated
15:41:42.437: Disconnected
15:41:43.109: Scanning for EFILive FlashScan V2 USB
15:41:45.640: Scanning for EFILive FlashScan V2 HAPI
15:41:45.843: Interface firmware version: 2.6.6
15:41:45.859: CAN-VPW Bridge Activated
15:41:45.890: Current protocol set to: "SAE J1850 VPW"
15:41:47.031: Current protocol: "SAE J1850 VPW"
15:41:47.062: Interface firmware model: FSV2
15:41:47.078: Interface firmware version: 2.6.6
15:41:47.093: Interface firmware date: Dec 14, 2008
15:41:47.125: FlashScan serial number: 003689852244
15:41:47.140: FlashScan license number: 003689852244
15:41:47.500: Getting status...
15:41:47.562: Status: OK.
15:41:48.406: Bootloader version: LS1B_v1.7C (08DC-9623)
15:41:48.406: Preparing PCM for reflash...
15:41:48.453: PCM seed is: $3EBF
15:41:48.453: Unlock attempt 1 of 1
15:41:48.750: Initializing PCM...
15:41:49.484: Initializing PCM, step 1 of 4
15:41:49.484: Initializing PCM, step 2 of 4
15:41:50.250: Initializing PCM, step 3 of 4
15:41:50.250: Initializing PCM, step 4 of 4
15:41:55.265: No response from PCM. Retry 1...
15:41:55.640: Not ready, waiting 1 second for retry...
15:41:57.031: Not ready, waiting 1 second for retry...
15:41:58.328: Not ready, waiting 1 second for retry...
15:41:59.625: Not ready, waiting 1 second for retry...
15:42:00.921: Not ready, waiting 1 second for retry...
15:42:02.718: Not ready, waiting 1 second for retry...
15:42:04.312: Not ready, waiting 1 second for retry...
15:42:05.906: PCM seed is: $3EBF
15:42:05.906: Unlock attempt 1 of 1
15:42:07.062: Initializing PCM...
15:42:07.828: Initializing PCM, step 1 of 4
15:42:07.828: Initializing PCM, step 2 of 4
15:42:08.578: Initializing PCM, step 3 of 4
15:42:08.578: Initializing PCM, step 4 of 4
15:42:13.593: No response from PCM. Retry 2...
15:42:16.671: PCM is in an unknown state.
15:42:18.781: Clear emisison related DTCs...
15:42:18.843: Clear DTCs for all modules...
15:42:19.843: Disconnecting ...
15:42:20.546: CAN-VPW Bridge Deactivated
15:42:20.562: Disconnected
15:42:20.562: Data transfer was interrupted.
15:42:25.828: Done!
This is becoming very frustrating.
