I need a tune for a twin turbo 2010 Camaro. Who would you guys recommend? I am in southern California but willing to drive a bit for a good tuner.
I think Justin is now down that way, he's also hooked in with EFI University.
http://www.blackbearperformance.com/
Yeh, he does the tuning on my Silverado with a 408 in it. I will be putting a turbo on that after this weekend because I want to be able to make it to the track for one last trip before the turbo install. I will most likely use him for that since he has been working on those pcm's for a good while and even has a truck himself. But, I wasn't too sure how he would be at working with the newer pcm's.
I was looking for someone who has worked on a lot of the new ones especially with the 6L80 and specifically the new Camaro. I will give him a ring to see where he is at with the newer stuff.
Bump. Getting close to the TT install on the Camaro.
The turbo is ordered and I will be doing the install hopefully by the end of this month. So if you know of any shops in the area that have worked on the new Camaro using EFIL please chime in.
I guess I need to start looking for someone who uses HPT in SoCal then I can read the file and make changes if needed with my EFIL.
Why not tune it yourself if you have efilive?
www.TheDynoShop.com
619-562-3933
