Originally Posted by minytrker
I have been running COS#5 for a few weeks and never ran the switch. So today I ran my switch and ground wire. I pinned the wiring harness when I had the motor out a few months ago. I have everything set like this
A0000 Disable
A0001 100.000000
A0002 100.000000
A0003 Disable
A0004 105.000000
A0005 8000.000000
A0006 101.000000
A0011 N2O Monitor
A0017 3000.000000
A0018 105.000000
A0012 511.992030
A0013 511.992030
I then set A0011 to pull 10deg of timing from 3,000rpm on up. I went out and did a wot run and had 28deg timing, flipped the switch and tried again, still had 28deg of timing. Im running my car on a rr if that matters. Im going to try and ground the wire straight to ground without a switch tomorrow. Any other ideas? I am 100% the pin is all the way in. If I remember right, I pinned 56 on the red connector.
