06 trailblazer ss
I got an 06 trailblazer ss I'd like to remove tq management and make throttle response faster and firmer shifts . Tbss is all but stock with intake and res delete . Can someone help me with the changes? I've got the efilive cable will I need a license?
If your pcm is not licensed yet. It will need license. Using a wideband. Tune the ve table, maf, remove some torque management. Shift points. Shift pressure. Shift timing. And it will be alot better. You can do a lot more things but you will need to read a lot.
i will be getting a license here soon and a wide band .. i guess what i am asking is if someone could coach me on this i will pay for your time
Im not an expert but your setup is almost stock. Itll be easy. Ill help you for free. Get a wideband. I use an lm1 with serial connection and works fine for me
thank you! .... i sent you a pm
