Any thoughts on this? What do I need to do to Correct? Was at the track last nightand counldn't log anything???
Have you validated all PIDs?
Sometimes PIDs will be invalid until you start logging.
Select your PIDs then start a log, see what happens.
Yes I did.( I think I did) I thought the same thing? Started to log and they came up N/A.
Explain Validate PID's thx
Scan tool> connect to PCM> Shit+F2
Page 48 of the scan tool manual:
Validate PIDs
Will query the connected vehicle to determine which PIDs are supported and which are not.
Unsupported PIDs are marked with a cross through their icon on the [OBD II (F7)] tab page [PIDs] sub page.
Passthru or BBL?
I validated the pids and worked until I hooked up the V@ to the truck and connected. It said I needed to update the software whichwas done 10 minutes ago???? Passthru
Did you select the pids then start a log?
If it gives an error, ignore it and select the pids anyway.
Uninstalled everything and will try again. Thx for the help and with it being Mothers Day I'm in and out.
Thanks again!!!
