AutoVE is already makin a big diff, wow!!!
After two logs and changes the car is cruising smoother than ever! Now, i've still got it in SD mode and she's having some idling issues. When I put her in gear from park or neutral she dies unless I give it gas at the same time. Also, she likes to idle up and hunt in park or neutral after i've been driving around (note: I've got a turbo 400 in the car and she's done this before, always have had some idle issues and they got worse with the 90/90, dunno if it has anything to do with the t400, cuz i've had it in there ever since i've had even a cam only motor, didn't seem to do it back then though, so I think it's something with the tune cuz of the big cam and good heads, etc). I did a search and am not finding any walk throughs for idle tuning, so any help with that would be great, after the idle, I guess i'll play with the wot, but i'm curious, all my cruising around is not changing anything in the ve for fueling at wot and I heard something about smoothing the ve table above 4000 rpm or something like that and then I was told you are supposed to devide 14.63 by whatever a/f you want at wot and that number will be the number to put into the pe vs rpm table, is this correct?
Also, I don't know if it affects anything, but I have no speedometer with the t400, and just out of curiosity, I keep seeing DFCO all over the place, what does that stand for?
