Originally Posted by
joecar
In the tables listed as OOR, see the cells marked with blue dog-ear corners, take note of the values, enter some value that is in range (like min+1 or max-1), do this on all tables, then save file, exit tunetool...
then open tunetool, go to those same tables and insert the old values back in those cells, save file, exit tunetool, reopen and verify no out-of-range messages.
Explanation: when the tunetool sees an OOR value, it displays the closest of min or max... when you then enter min or max, the tunetool thinks you did not edit the cells (since it compares what you entered to what it was displaying)... so you have to enter something different and save/exit, reopen and enter your proper min or max... little bit tricky.
