I have a 01 suburban, 5.3 LM7 engine. I was trying to reflash to correct speedo and it would bring up gen3 ecm. when i would try to reflash it would say no responce from ecm. You guys have anything for me to try?:nixweiss:
Are you sure you selected 99-08 LS1 and not 97-98?
it didnt ask it just popped up like it already knew
Obviously, it doesn't know, or it's confused. Try downloading the data that's currently in the PCM, and when it provides you with an opportunity to enter the type of PCM, select 99+ or 99-08 LS1 (can't remember which way it comes up) and see what happens. If it links up and downloads without a problem, it should upload fine.Quote:
Originally Posted by newguy2diesel
cool thanks. ill keep you posted
