Originally Posted by
5557nut
UPDATE!!
All is fixed no codes and headed to a dyno Friday.
Problem was with a BRAND NEW PSI harness. The pins 39 and 71 for E38 J2 ecm connector were not seated and 39 (injector 4 pulse) and 71 (coil 8 pulse) was not push in all the way, so barely touching causing the intermittent open code P0204, P0354. Even though I had ohm the wire (not taking the connector apart) and ohm the injector and coil, I saw no smoking gun. It wasn't till I pulled the pin cap on J2 that I saw the problem. All is fixed and the LS3 runs pretty good for a newby tune. Who would think of that kind of problem on a new harness.
