November 2015: EFILive Public Stable-Release
Please download and install both the V7.5 and V8 software packages.
Both the V7.5 and V8 software were updated in this release, you must update both software packages.
Updating from earlier releasesThe "Check for Updates" option in both the V7 and V8 software packages is now active. However, automatic patching of previous versions to this latest stable-release is not supported. That means when you or your customers perform the "Check for Updates" option a message will be displayed explaining that a newer version is available but that the currently installed version cannot be automatically updated/patched. Instead, the user should download the latest EFILive software from EFILive's web site and install the downloaded files manually (from here:
http://www.efilive.com/latest/cat/download-efilive).
Future, minor updates to this stable-release will be available as automatic patches via the "Check for Updates" option.
Release Notes:Whats New
IMPORTANT
The Auto-Lock implementation for E39, E92 and E98 controllers requires that tuners and customers upgrade their AutoCal and FlashScan firmware to V2.07.86 or later. The upgrade is required to prevent *.ctz and *.coz tune files created using this pre-release (or later) from being used with older software or firmware.
Tuners: If you update your software and firmware and attempt to deliver new tune files to your customers, then your customers must also update to the following versions (or later):
- V7.5 Software: V7.5.7, Build 288
- V8 Software: V8.2.2, Build 281
or they will not be able to flash those new tune files. Existing/old tune files will continue to work normally with the new software.
Known IssuesPlease post new issues, questions or clarifications (large or small) in this thread.
As new issues are verified they will be posted in the
Known Issues thread.
Version Numbers:
After installing the latest release you should have the following software, boot block, firmware versions installed:
EFILive V7 software: V7.5.7 Build 298
To view the installed version, select Help->About (in the V7 Scan or Tune software).
EFILive V8 software: V8.2.2 Build 289
To view the installed version, select Help->About (in the V8 Scan and Tune software).
Boot Block: V2.07.07 (Feb 07, 2014)
To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
Firmware: V2.07.94 (Nov 24, 2015)
To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
The EFILive Development Team
