single wire P/N in gear setting
hey guys, do we have a setting for LS1B to cang the gear selector to the single gray wire for P/N and in gear setting like in HP tuners ? if not can we get the setting added please, ive just tuned a boat with a camed LS1 and im having trouble with it stalling when its put into reverse, got it pretty good going into forward but the extra load of reverse is stalling out, everyting seems to be working as it should, its adding timing and air but not fast enough.
not sure if setting it up to add extra air when its put into gear is going to help or not but im out of ideas at the moment, i thought maybe a less aggressive pitch on the propellor and the guy will tri that as he does have another propellor but it means he will have to run it at higher rpm for barefoot skiing.
thanks
pete.
