1 Attachment(s)
Apr 05, 2023, V8.3.37 Public Release
Full Release Notes:
Version Numbers:
After installing this release you should have the following software and firmware versions installed:
- EFILive V8 software: V8.3.37
- FlashScan/AutoCal V3 Firmware: V3.00.106
Download here:
Known Limitations: Limitation #1: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However, the DMA PIDs may no longer return valid data.
Workaround: EFILive recommends stopping the data log and restarting the data log when switching off the ignition for extended periods.
Limitation #2: When opening CMF (CM2450B) Cummins 2022 tune files, the EFILive software will complain with the following message:
Attachment 24392
That is expected and the message may be ignored. We have only added the option to open CMF 2022 stock files so that EFILive can flash stock files. EFILive cannot be used to update the check sums of modified files. Modified files cannot be flashed.
Ignore the message if you are opening and flashing a 100% stock tune file. Do not attempt to flash a modified file, it will fail at the end of the flash and the vehicle will be left in a no-start condition until a stock file is flashed in.
Workaround: None.
Limitation #3: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), that are specific to a custom operating system such as DSP2 or DSP5 PIDs when running a stock operating system, the values returned by those DMA PIDs will not contain valid information and should be ignored.
Known Issues:
Issue #1: When reading E35 controllers, the EFILive V8 software shows an error indicating that an "Index" is "out of range". You then cannot save the file that was read from the E35 ECM.
Workaround: Use update
V8.3.38.
Regards,
The EFILive Team
