3/18/08 What do I need to have to be prepared for the new beta release
All, I am doing a track day April 11th. I would like to have the BB Logging working by then so I can log my entire session on the track. I have read all the threads and I'm a little confused. Can someone help me clarify what I will need to be be prepared for the new beta release that is due in the next day or so.
From what I understnad I'll need to make a cable up if I want to use the serial connection for my LC-1. That cable will basically need to go from a headphone jack to the serial plug on the V2. That will require either swapping some pins, or using a null modem adapter.
To log for extended periods of time, 4 or 5 twenty minute sessions I assume I'll need to log to an SD memory card. Is there a limit to the size of the SD card I can use? What size will I need to log a total of 2 hours of run time. I'll probably be logging somewhere in the range of 20 parameters or something like that.
Thanks for the help.
