I noticed that the tune tool is not marking the selected area in E78 and E39 ECMs
So I want to know if there is a procedure to make this hapen as in LS1B and E38
Thanks in adance
Thanks in adance
You need to go in and edit the cal_link.txt file, open the file up (save another copy) and add the tables you want to see. I did this for the P10 years ago, just have to copy the text/file over every time you install an update.
Why it was supported for LS1B, E38, E67 but not the newer ECMs like E78 and E39 ?
Probably the cal_link.txt file still has to be updated by Paul.
[ and of course, in the tunetool properties, under the Scanner tab you have to checkmark "Highlight Scantool Selection", and scantool/tunetool must agree on units ]
If you know what the link pids are, you can edit them in for the relevant tables (multiple link pids are comma separated).
Joe can you make an example for High Octane spark table in E78 so i can edit it until Paul can update it
Post your tune file, I'll send you a cal_link file for the HO table.
Here is it
Please Joe write the lines you will add to the link file so i could know the logic
