If i set properties to display VE in grams per cylinder, the table and map values are incorrect
1.26 g/cyl @ 400rpm, 15kPa and 10 g/cyl the efi max limit by 2000rpm
g/cyl should be between 0.08 to 0.8
screen shot attached
Blacky, can you help?
Can you check the cylinder volume calibration.
It probably says 0.75CC, when it should say 0.75 liters.
That is being fixed in the next release.
The problem is the axis on that table have been swapped and EFILive has not been "told". EFILive is assuming that the columns are MAP values. It uses those column labels to multiply out the g/cyl values. Unfortunately, for the E40 the column headers are RPM values (not MAP values) which makes a mess of the g/cyl calculations.
It is on the list of things to fix. Not sure when it will get done.
