OS5 TPS VE Table setup?
What steps are taken to setup the TPS VE table after you have AutoVE tuning done? What figures do you start with and how to incorperate them into the map? Which perimeters to set up the map in the scan tool?
It'd be so cool to have an OS5 tutorial:D
See tordne's thread on the topic. http://efiforum.iqd.co.nz/showthread.php?t=2599
Basically there is a Calc VE pid. Make sure you chose the default units and not %. Then make a map up, use copy and fill function to fill in the gaps.
You normally only want it for low map regions.
End of OS5 abridged tutorial ;)
Mine is done at just 1400rpm and below. It makes a good difference BUt it took quite a bit to get it dialled in.
1400rpm <10& <80 MAP
Yeah sorry I meant low RPM regions :)
I have mine setup at 2800 RPM and below.
Bill
:notacrook:
