P1336 is the Crankshaft Variance code. Is it's function mainly for EPA reasons?
Pretty sure it deals with if you put a bigger cam in it will cause the code to flip and come on.
"It doesn't relearn "automatically". It is a procedure you have to do with the Tech2. Many cals don't use it, most Vettes for example. If you swap PCMs you often have to run it again in the "new" vehicle. All new PCMs (running cals that use that test) need to have it done when installed initially. Tunring it off if sending out an exchange PCM prevents the guy having an SES light and not knowing what to do about it, or having to pay somebody (the GM dealer gets as much as $100.00) to do it. Try convincing a guy there is nothing wrong with the PCM, when all they can come back with is "my old PCM didn't turn the SES light on". They will often think you should pay for them having the relearn done. Most of the time it won't be required if the PCM has "learned" once, maybe 10% of the time it will need it again in another vehicle.
The vehicle will run fine either way, it causes no problems being shut off."
Answer from another thread.
Moved to "General" section.
It's function is for accurate misfire detection.Quote:
Originally Posted by onfire
Changing the TC may cause this code.
Sometimes, the crank relearn does not work for some reason or other, so it's just easier to turn off the code than to deal with it.
More info...
Quote:
Originally Posted by GM Service Manual
Good info.
I may try a crank relearn with EFI LIVE just to see if it works.
