V2 vs V1 - Dual LC-1 WB Analog Inputs
Something I came accross while verifying my LC-1 Widebands.
The analog input coupler on V1 had a single shared ground (3 wires 1 ground). I noticed when I got V2 the couplers had 2 wires each (positive and ground).
I jumped the ground just before the coupler to basically share it again and I found that the voltage on the second input appeared to stay at zero.
Easy fix to just connect LC-1 ground and both work great. it doesn't seem logical but I am interested to see if anyone has seen this.
I also noticed that the Orientation of the little sticker on the back of the V2 unit is a little strange until you drink 4 shots of Vodka. Then it clears right up:muahaha:
V2 :rockon:
Jim
