Fuel gauge calibration
Hello EFILive folks,
I'd like to know whether the fuel level sensor calibration values can be added to the Gen IV (E38) operating system calibrations. In my last vehicle, EFILive could modify a table that correlated the fuel level sensor to the actual fuel level in the tank. In my new vehicle (using a 2007 LMG operating system), the table is not present, only a value for the tank capacity is present. This is a problem because the fuel sender needs to be calibrated for the new tank (this is an engine swap). Currently it is reading backwards (0% fuel level = 100% fuel level according to the ECM). Are there any plans to add this table?
BTW, the operating system I will be running for this is 12630501.
Thanks,
Patrick
I'll look in to it.
Thanks, Ross! That will make my life much easier.
FYI this feature has been added to the latest EFILive release (v 7.5.5 build 70) calibration definitions.
