Seem to be losing ground....
I had a little bit of KR, interestingly only on light throttle after decel. I tried adding fuel in the ranges wher I seeing the KR by increasing the VE slightly and by decreasing the multiplier vs Lambda in the PE vs RPM table. Then I was getting KR in the high MAP areas so I added more in those ranges and in the commanded fuel while in open loop table. Any suggestions on where I am screwing up? (be kind;) ). Now I am getting more KR than ever and finally just reloaded the original calibrations to avoid any damage from ping.
