Getting connected, V2 flashscan and V8. Newer user
I am new to the EFILive tool and trying to scan a E38 ECM with 6L80 trans. I tested the tool in V8 and it detected the proper ECM and TCM but when trying to stream the live sensor data, it just says "that feature is not yet available". I am not sure what this means.
When I toggle over to the OBD interface, it will give spec on the controllers but when I try to check for DTCs, it also says "that feature is not yet available"
All I am trying to do is scan for active body codes and stream body code data to troubleshoot a traction control/stabilitrak warning lamp status.
I borrowed the device and has only been used for tuning the Duramax diesels. I am unsure if there is even more licensing for this or what?
I was instructed to test with V7.5 but when I plugged in and attempted to connect, the software indicated the flashscan was not compatible with the software and I needed to use V8, then update the firmware. I did so but still will not function.
Can someone direct me a bit here?
