Commdoore L76 (e38) and 4L80e (T42) issues
Hi Guys,
Have setup a vehicle with a E38 ecu and T42 trans ecu from a VZ Commodore L76/4L60e
The vehicle is shifting gears and vehicle is very sluggish although im getting Lost comm codes between the ecu and tcm, Uxxx codes
I have installed a T42 trans tune for a 4L80e originally 4L60E
I have also modded the harness and wired it up as if it is a 4L80e to suit a T42, inc wiring the external ISS and swap pin in the Big round connector etc
but I am not getting any engine or trans data from the ecu or tcm while using the efilive scanner, can read and write all ok. and also can watch live data with hptuners scanner, but have no vehicle speed....
Do I need to run the 4L60E tune file and swap data?
Anyone else had any similar issues?
Cheers Mat
