Originally Posted by nqcv8
Hi Bill
You can also just run the ground to pin 56 with a second relay from the Nitrous arming switch...saves having multiple switches.
I have only just started playing with Nitrous, If its a wet shot you need to not worry to much about the VE table.. just change the Jets in the fuel nozzles, I plan to make some minor adjustments with the A0015 to get the AFR's exactly where I want them.
A0016 actually reduces the timing by whats in this table...so you want to pull 19 degrees out?
my A0016 table varies between 3 and 4 degrees thru out the rev range.
Hopefully some of the more experienced guys with NOS can help with some of the other questions.
