DTC's from non-GM vehicles
Should the current firmware for the V2 support pulling DTC's from CAN-based non-GM vehicles? If so, would it be just powertrain codes, or would it be powertrain, body, chassis and comms like the GMs?
I tried pulling codes from a 2004 Taurus, and the thing is it got some data, but was unable to get codes from the ABS module. It also was able to pull data using the "Record All Diags" (see below). Another thought, the "Record All Diags" requires you to slect a PID list... Any chance of having it run like it used to where it just pulled all data so it'll work with non GM CAN-based vehicles?
Code:
[ECM INFO]
VIN=Unknown
OS=Unknown
Stream=LLY
[ECM CVN]
0=AE36C2F3
[System Readiness Tests]
MIL=OFF
DTC_CNT=0
MIS=Ready
FUEL=Ready
CCM=Ready
CAT=Ready
HCAT=N/A
EVAP=Ready
AIR=N/A
ACRF=N/A
O2S=Ready
HTR=Ready
EGR=Ready
[DTCS]
; No DTCs detected.
[MODE06]
;ID MinLimit Value MaxLimit Units Result
0101.0= 0.0000, 0.4499, 7.9953,V ,OK ,"Rich to Lean Sensor Threshold Voltage"
0180.0= 0.5000, 0.8062, 7.9953,V ,OK ,""
0181.0= 465, 948, 3000, ,OK ,""
0201.0= 0.0000, 0.4499, 7.9953,V ,OK ,""
0281.0= 220, 529, 3000, ,OK ,""
0501.0= 0.0000, 0.4499, 7.9953,V ,OK ,"Rich to Lean Sensor Threshold Voltage"
0580.0= 0.5000, 0.8340, 7.9953,V ,OK ,""
0581.0= 465, 958, 3000, ,OK ,""
0601.0= 0.0000, 0.4499, 7.9953,V ,OK ,""
0681.0= 220, 516, 3000, ,OK ,""
2180.0= 0.000, 0.090, 0.699, ,OK ,""
2280.0= 0.000, 0.074, 0.699, ,OK ,""
3180.0= -2.266, 0.205, 32.767,kPa ,OK ,""
3181.0= -32.768, 0.205, 2.260,kPa ,OK ,""
3184.0= -32.768, 0.548, 4.836,kPa ,OK ,""
3185.0= 1.494, 6.611, 32.767,kPa ,OK ,""
3A80.0= 0.00, 0.00, 0.00,Pa ,OK ,""
3A81.0= 0.00, 0.00, 0.00,Pa ,OK ,""
3A82.0= 0.00, 0.00, 0.00,Pa ,OK ,""
3B80.0=-8192.00, 324.75, 609.75,Pa ,OK ,""
3C80.0=-8192.00, 92.75, 214.75,Pa ,OK ,""
A180.0= 0, 0, 19659, ,OK ,""
A181.0= 0, 0, 655, ,OK ,""
A182.0= 0, 1310, 19659, ,OK ,""
A183.0= 0, 0, 655, ,OK ,""
A184.0= 0, 3007, 9388, ,OK ,""
A20B.0= 0, 0, 65535, ,OK ,""
A20C.0= 0, 0, 65535, ,OK ,""
A280.0= 0, 0, 19659, ,OK ,""
A281.0= 0, 0, 655, ,OK ,""
A30B.0= 0, 0, 65535, ,OK ,""
A30C.0= 0, 0, 65535, ,OK ,""
A380.0= 0, 0, 19659, ,OK ,""
A381.0= 0, 0, 655, ,OK ,""
A40B.0= 0, 0, 65535, ,OK ,""
A40C.0= 0, 0, 65535, ,OK ,""
A480.0= 0, 0, 19659, ,OK ,""
A481.0= 0, 0, 655, ,OK ,""
A50B.0= 0, 0, 65535, ,OK ,""
A50C.0= 0, 0, 65535, ,OK ,""
A580.0= 0, 0, 19659, ,OK ,""
A581.0= 0, 0, 655, ,OK ,""
A60B.0= 0, 0, 65535, ,OK ,""
A60C.0= 0, 0, 65535, ,OK ,""
A680.0= 0, 0, 19659, ,OK ,""
A681.0= 0, 0, 655, ,OK ,""
A70B.0= 0, 0, 65535, ,OK ,""
A70C.0= 0, 0, 65535, ,OK ,""
A780.0= 0, 0, 19659, ,OK ,""
A781.0= 0, 0, 655, ,OK ,""
