KOEO check engine lamp flashing- E67 GMPP ECM
Hello, could someone verify the lamp operation?
The car-project is not to the point of running yet but I am going through and checking the operation of things.
The engine is a GMPP LS7; harness based on GMPP with an LS7 programmed E67.
When turning the key to the on position, the check engine lamp flashes, as opposed to just being on
From what I read,in the KOEO postion, many ECM's after 05 will flash the lamp if the emission tests have not yet run.
Of course, as the engine has never fired, a number of tests do come back as not run.
No codes are stored,
Also, with an E67 , should I be able to see MAF readings if I blow air across it?
Or does ECM not register the airflow if it does not see that the engine is actually turning?
I checked the wiring and it looks to be correct comparing to other GM cars using this MAF
The air temp is reading, the MAF gets warm; the air temp will change if I blow over it.
But no MAF readings.
Thanks for any help
Gerry
