1 Attachment(s)
RAFIG help.... unsteady idle after cam.
i had read the radig tutorial on here and made the pid list and made sure each pid is valid and proper units to match the maps and tables in my tune file. although all the pids show as they are valid i click the red circle to data log the rafig process and the only pid that has the accuate info is my wbo2 sensor. are some of the pids only valid in the older os ? i have a 2006 vortec max. just installed the elgine e-1839p and removed the cats. the file is listed below. the idle is low due to stock converter and the truck seems to have an unsteady idle and even worse with the ac on. enough to the point the ac will be commanded and the clutch will engage then the rpms will fluctuate and the ac clutch gets turned off even though the ac is being commanded by the hvac buttons. i will soon be doing the 862 heads and a nbss throttle body with the 88mm tb and would like to get this sorted out before doing more mods. any help is very much appreciated.
hard times, criticism and helpfull info is all welcomed haha.
