Using LBZ injectors and pcm on detroit diesel
Got a good question for you guys.
Someone i chat to on another forum is planning to try to make a detroit diesel 4-53 mechanical injection into a common rail system using LBZ duramax injectors and PCM.
Just discussing if you can disable injectors using EFI or would it be possible to fire 1 injector twice by wiring the injector ground to the PCM twice? Was thinking of putting a diode on the grounds so it will not backfeed the PCM.
lets hear your thoughts
