1 Attachment(s)
any suggestion?? need help with cam
i cannot get my truck to idle or run right what so ever. ive tried playing with the VE tables to get it to run good enough to do an auto VE but cant seem to get it right. can anyone look at my tune and help me out in which direction to go to get it to run right. heres my tune file Attachment 5240.
here is my cam specs INTAKE EXHAUST gross valve lift .510 .510
duration @ .006 tappet lift 270 276
valve timing open closed
@ .006 INT: 2- BTDC 40 ABDC
EXH: 47 BBDC 3- ATDC
installed @ 111.0 intake center line
INTAKE EXHAUST
duration @ .050 218 224
lobe lift .3010 .3010
lobe separation 113.0
RPM band 1500-5500 and is a roller cam
the heads also have a 5 angle valve job with bowl work done and a set of 1.7 rollers rockers. mild intake side port work.
any pointers would be greatly appriciated as i am completely stumped with the tiny bit of knowledge i have so far.
