I got a car in that has a ls7 swap.
Car will start but wont stay running.
Im using a 2006 vette file that i have that works well with big cams.
What patc do i use for this.Thanks
12602922 is the current os.Thanks
Also where do i loctate the patc.Is it in te custom os section
OS 12602922 is an older 2006 Corvette OS. It has been updated 3 times (via TIS) - the current OS is 12614682. These were used on 2006 Corvettes with LS2 and 6L80 or manual transmissions, and LS7 with the manual transmission (only option).
Operating System Patches (red folder) are found under the Engine Operation main folder. These are only visible if your V2 is plugged into your Notebook computer when you open the tuning file. There are patches available for OS 12614682. I don't have the older OS (12602922) on file to confirm patches for it.
Regards,
Taz
Ok so there is no patch for this OS then.that sucks.I didn't really want to start from scratch on the tune.
You don't really have to "start from scratch" - you can either update the OS via TIS, and copy over your previous work - or there is a 2006 Corvette LS7 tune using OS 12614682 available for download on the Holden Crazy / Tune File Depot website - again you would have to copy over your previous work.
Regards,
Taz
Last time I looked that old 05/06 OS had a VATS patch. When you looked for it, did you restart EFILive with the V2 plugged in?
