What happens when you go into boost?
I know you go real fast :wink: But really, if you have some type of forced induction, what does the computer use for a spark table at that stage? The spark table stops at 105kPa and I don't see any other provisions such as spark v. rpm at WOT as in the PE table. So does the computer send the same timing number that it was using for 105kPa at a given RPM for anything above 105kPa? Or do you have to revert to other methods to scale everything down? In other words: How the h*** do you tune for force induction without that two bar map support :D
