Well guys I'm baaaaaaaaaaaaaack!!! Cooling fan OS problems.
:help: This should be simple but as with most of my problems, has turned into a nightmare.
This is that daily driver Volvo with an LH6/4L60. Because the application is from an SUV it had an engine driven fan. Obviously I swapped it to a dual wire electric fan from a Volvo. Simple 3 wire...low speed/high speed/ground on a single electric fan. I utilized an aftermarket fuse panel with 2 fan relays. After repinning 2 terminals from the E40 to be able ground the 2 relays I reprogrammed the GTO fan settings into my tune. Now the low speed fan will come on at a certain temp but will not shut the fan off until I turn the key off. Even after the temp drops to below the thermostat temp. Also the high speed relay will NEVER kick on, even after pulling the fuse for low speed to make certain the engine temp goes high. I HAVE manually grounded low/high speed ECU terminals to verify proper fan operation. Different temp settings don't help either.Also I'm NOT able to log fan on/off because the OS is from an engine driven fan setup.
I tried a FULL flash with GTO settings but still no luck. So I now look to the powers that be (hint,hint) to find out if I need a GTO OS to be able to use my electric fans. I probably don't mind doing this as I have not been very happy with DOD operation. SO I guess my question is wether or not an OS change is in order for proper electric fan operation?
For those of you wondering about DOD/AFM use in a engine swap situation wonder no more. I see now that the engineers at GM had there hands full with N/V/H issues when they designed this. I've never driven a DOD GM truck in DOD mode. The exhaust on mine sounds awful in DOD mode. While my exhaust is not loud...2 CATS, single 3 inch stainless, 2 Magnaflow straight thru and long tube headers. Car is completely unassuming in V8 mode until you step on the gas and and light the tires! In V4 mode the vehicle shakes violently and has a horrible 4cylinder drone and feel.
I would not waste my time trying this DOD thing again. Next one will be full on GTO or Camaro setup. This would be a COMPLETE sleeper with a small turbo setup.
Thanks for the help, sorry for the rambling! John:rant:
2 Attachment(s)
both fan schematics enclosed
Well the GTO fan relays are grounded by the ECU. Here are both diagrams. I still think it is an OS problem. Just need the hire ups to verify.
Thanks, John......In want of a mega-burnout!
