how much are you guys spraying (shot size) and what multiplier are you using. thx.
I am using a wet kit so I don't know if it will help you much, but I use a 1.2 modifier where my window switch is set to "soften" the hit and prevent a lean spike. It then levels off to about 1.08 to run a little richer than normal, but I could just put a bigger fuel jet in the car.
