07 lbz maf on 09 lmm
Can I put the lbz maf on the lmm ? I have 5 volts at ecm maf unplugged and 2.4 plugged in it rises if air moves across it. I see you can change maf from digital to analog but this did not fix it. I still see no gps and have a code for it.
Either my ecm is def, I am doing something wrong or Its not plausible.
:good:
Since nobody knows the answer Ill give it to you. NO... You can not change the parameter in EFI to analog and make it work. It has to be an LMM MAF.
I was just hoping some one would save me a little time testing the two signals.
